Removing plastic piece around gas cap...
Why isn't it coming off, i removed the two screws that are holding it and it seems to be stuck somewhere at the top right hand corner but there are no bolts holding it down.....
Anyone remove this before?
LS1Tech Administrator
Received 1,703 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
It's a bit tricky the first time, there is a lip built into the plastic piece on that corner that grabs the edge of the metal quarter panel. You have to move the plastic piece down and away (as far as you can) from that upper right hand edge. With a little fiddling it'll pop off, and after that it'll all make sense. First time took me quite a while of messing with it, now I can hit the angle just right and pop it off it about 1 second.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Yep, there is no need at all to remove the inner lining to get that piece out. You want to push it down as far as you can on the opposite edge where that lip is (so push down on the lower left section), and while doing so you also push down then pull out on the edge of the upper right hand section. It's really just a matter of fiddling with it till it pops out, but those directions should help, and once you get it the first time it's super easy in the future.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
