GM why not a DOHC LS motor?
#61
Pontiacerator
When an OEM makes an engine, they have the following priorities to worry about (there are a lot more, but this answers the question)
Packaging size
Power output
Emission
Weight
Cost
Lets compare the 5.0 mustang motor to the LS3
LS3 is smaller
LS3 makes more power
LS3 is lighter
LS3 is cheaper (parts are used on all ls series of motors to get quanities of scale vs a single application)
Packaging size
Power output
Emission
Weight
Cost
LS3 is smaller
LS3 is lighter
DOHC advocates get all excited about hp/displacement. But if a pushrod engine makes more average torque with fewer parts, a simpler design, and lighter weight, while making comparable fuel efficiency at a larger displacement, where's the the benefit of the DOHC?
In the Motor Trend Camaro/Challenger/Mustang comparo, the Mustang got the worst gas mileage of the three, despite being the lighter car. I'm convinced that the new Mustang GT is an awesome car. I'm not convinced that it's DOHC motor gives it a decided advantage against the LSx.
#64
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Packaging, efficiency and cost make the LS series engines attractive to not only GM, but to the aftermarket and hot-rodders as well. The HP/TQ area under the curve is a great point as mentioned above...
Having said that, a modern iteration of the LT5 would be sick!
#65
Some of these comments are so funny I couldn't avoid commenting. Especially the people who say the extra weight of a twin cam 32 valve setup would be a bad thing. Unfortunately we can only use examples from Ford because they make variations of their 4.6, 5.0, and 5.4 offerings. The difference between the 5.4 single cam and the 5.4 DOHC is a measly 15 pounds. So when ya look at all the extra available power with the DOHC setup, vs the power to weight differential, this argument doesn't even come close to holding water.
The other argument I love is the thought that the LS series of engines last longer and make more power than the DOHC competition. When you look at the power per liter you'll be laughing with me. And let's be honest here..... If GM built a twin cam setup good, doing it the right way it would last just fine. Those kids in the Hondas buzz those engines to 9,000 RPM, make 100 hp per liter, and easily do 200,000 miles.
#66
LS1Tech Administrator
Received 1,696 Likes
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
I'm sure the "power per liter" arguement makes the ~150hp honda guys feel a lot better when they get ripped apart by a 350hp LS1.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
