OK, does anyone else get stressed..
thats the problem...if you dont have another set of wheels to get to work in..then its always a crash fest to get the car torn apart, mod/upgrade/fix whatever is wrong etc..then re install everything and try to get to work.. the best way i have found to do it...
#1 get all your car friends together
#2 Order **** ton of pizza/BK
#3 Have beverage of choice ON HAND
#4 DONT RUSH THE JOB..can't stress that enough..
#5 work in sections and take breaks...dont get stressed out..
and when its all said and done DON'T FORGET who came to help YOU .. and return the favor..
oh yeah ..take lotta pics/ video because you KNOW stupid **** is gonna happen!!!
LS1Tech Administrator
Received 1,685 Likes
I would never start a voluntary major project on a car that was my only means of transportation. Too much unnecessary stress. Then again, the single car lifestyle is just not for me anyway, and I keep my daily driver almost totally stock. Only reason it's ever down is for needed repairs.
Right now I'm at the point where nothing much scares me. I've done a rearend, shocks, struts, rebuilt the front end, fuel filter 6 times, drained and changed ALL fluids and have done the brakes more times than I can remember, alternator, and of course spark plugs. To me its easier to work on than my wifes Tahoe because I have spent so much time working on it, I know all the stupid little things to watch out for. I have never done a clutch before I do though I will do some research. If it doesn't work the 1st time at least I have the Cobalt. Almost all of this stuff has been done pretty much alone, I had a little help bleeding brakes and lining **** up but for the most part it was just me. I love the results right now, The Camaro runs and drives better than it ever has because of the **** I have done. I would be lying if I said everything went perfect and I never got pissed off because it didn't you just keep going, it's good bonding time too. Enjoy it thats what the car is for.
I only get really stressed when I have someone else work on my car (warranty only, I do all other stuff myself). I just picture some 18 year old doing second gear clutch dumps when "road testing" my car after doing the work.
Location: Holmes County (thats right Amish Country), OHIO
1 Post
This just makes me think of how I drop my transmission. This the the second time doing it. It takes a while jacking it up but once its there its not bad. Getting it back in is the bitch. You have to lay on your back under the car, roll the T56 on you, then your knees lift the front of the trans and your arms get the back. Then its up and in and get the bolts with in arms reach. I could buy a trans jack but i'm to tight. I'm not even sure I could get the trans on a jack and under the car at the same time. Anyhow here's the pic.
