Pic request 98 ls1 intake
More specifically where the brake booster and ac vac lines connect. I need to reconnect my ac vac line and don't know what the feel around for..
Vacuum line is the small one on the pass side, brake is the big one. You should connect the brake booster hose before you put the intake in as you cannot get the clip on with the intake all the way in. All the LS1 style intakes are the same, this is the only pic I had handy.
Thanks. The brake booster is still connected, it's just the ac line has just come loose. I'll make sure to remember that when I put a fast manifold in it though
