General LSX Automobile Discussion Non-technical LSX related topics.
Aeroforce interceptor ?
Old Oct 6, 2010 | 10:22 AM
johns777's Avatar
Question Aeroforce interceptor ?
Morning forums,
I ordered an interceptor gauge and was wondering how accurate the HP and Torque numbers on it are going to be? Does the PCM know your new HP numbers once you bolt on a ton of stuff? Sorry for the newb questions, just wanna get a feel for how accurate it will be before it gets installed.
Thanks John
Old Oct 6, 2010 | 10:37 AM
RsSean's Avatar
There is adjustment on the gauge thur setting or what not adjust. But to answer your question it is not close at all. I have messed with a for a while and get said "F" it.
Old Oct 6, 2010 | 10:39 AM
johns777's Avatar
Ok I kinda thought it wouldnt be that accurate on that aspect of it, but thats not why I bought it in the first place. Thanks for the quick response. Anyone else have any experience with the hp readings on it?
Old Oct 6, 2010 | 09:57 PM
senicalj4579's Avatar
i got one 2 weeks ago. i got it to basicaly monitor coolant and trans temps. that part is accurate but i doubt the power readings are
Old Oct 7, 2010 | 01:59 AM
bad_408_vert's Avatar
After boltons and other modifications your car would need a tune for the bcm to "understand" all the new changes and give accurate information.
Here's a link to thread on here that REALLY goes into detail about this gauge with video demos by member.
Old Oct 7, 2010 | 09:31 AM
johns777's Avatar
Thanks for the link to the thread I have watched that video before. It didnt really answer my question and that is the reason I made this post.
Old Oct 7, 2010 | 09:47 AM
Honestly,I dont even know how the pcm is going to be acurate with any power numbers. I havent tried it maybe I should.
Old Oct 7, 2010 | 11:28 AM
johns777's Avatar
Well if you know your current power numbers go for it and compare. Would be nice to see how close they are reading. Post up some results afterwords if you don't mind, I know I would be interested in seeing that data and I am sure others would be as well.
Old Oct 16, 2010 | 11:59 PM
PowerShift408's Avatar
I will tell you that the 1/4 mile asset of the gauge is pretty close.
Old Oct 17, 2010 | 07:16 AM
If you use it to check your o2s dont make the same mistake I did. Someone chimed in on post #22 thankfully
https://ls1tech.com/forums/pcm-diagn...0mv-450mv.html
Old Oct 17, 2010 | 07:47 PM
johns777's Avatar
So glad you posted that. I have had o2 sensors codes forever and I was going to check em out with this gauge.
