Tranny Flush Question
This may be a silly or stupid question, but I wanted to ask the Gear-head experts on here anyway. I have put about 80k miles on my 04 Z71 in the last 3 years I've had it, which it now has a total of 160k miles-all highway miles due to commuting. My step-dad mentioned that we should probably flush the tranny and change the filter. However, another auto enthusiast friend of mine advised me that if I have gone this long without changing it...don't. He said that if a tranny has gone this long without the fluid being changed, if I flushed it now, it would most likely take a crap. He advised me just to make sure that the fluid level is full instead of flushing it. Don't have money for a new tranny, but would like to do maintenance so I can keep my truck in peak condition as long as possible.
Any truth to this?
TIA,
Jamey
Any truth to this?
TIA,
Jamey
Any truth to this?
TIA,
Jamey
Any truth to this?
TIA,
Jamey
Yeah.. Don't flush it. Too risky. That can have a tendency to loosen up any gunk that's holding it together.
I've been using Lube Guard Red stuff for a while with good results. It's just a conditioner. Had my last truck feeling like the trans was brand new. Just keep up with your scheduled maintenance.
LS1Tech Administrator
Received 1,792 Likes
If you're going to do a complete flush with a machine, that should be done at least every 50k miles. To start that at 160k is just asking for trouble, IMO.
I went to go see about getting a flush last summer/fall. The trans guy (who owns a LT1 camaro very nice) told me its not wise to do it. He said he might not even bother dropping the pan with so many miles on it. I asked if hes actually seen bad things happen from a flush and he confirmed hes seen more than enough evidence that a flush is VERY risky. So he talked me out of it and I dropped the pan,cleaned pan, changed filter, fluid, and gasket. Then I added a trans cooler and now im getting ready to drop the trans to put in the ss3600 so hopefully it hold up!
The Trans was F'ed up prior and the dealer was being a pain in the *** about pulling it, so I told them to flush it and I'll be back in the morning. It was toast a few hours later.
I've never had a problem with a flush machine, so long as the trans was flushed *at least* every 50k miles. Past 50k without ever being flushed, I would not do it.
I think the only people you'll find that have had immediate trans failure right after a flush are those with over 50k miles since the last flush.
The flush loosens up **** that would otherwise stay put, some of it can't pass through the filter. The filter now has a restriction and the fluid circulates much slower, the tranny runs hotter and is more prone to failure.
I do agree that if it is done routinely it shouldn't create any issues, I just don't agree with not changing the filter. Ya, it cost more and you waste some ATF but Tranny's aren't cheap either.
In my case, My cooler lines were leaking so I brought it to the dealer had the cooler lines replaced under warranty. When they replaced them, they should have also replaced the cooler and radiator but GMPP did not approve the claim. There was a restriction in the cooler causing my Tranny to run hot @ 200* and would slip occasionally on the 1-2 shift. They insisted it wasn't slipping and the temp was normal even though it was running @ 120* prior to replacing the lines. I told them to flush it then I took the truck out plowing for 5 hours until it failed. They gave me a brand new Tranny, Radiator, Tranny Cooler and Lines courtesy of GM.
My issue with it is that most people just flush it but never change the filter.
1 Post
After having an argument with a BG rep he decided to let me flush a truck and then take the pan down after the flush. Needless to say he lost the bet by a long shot on a 65,000 mile 2500HD. After flushing 15 quarts through the system the pan still had a significant amount of debris. My argument was that you can't get everything out of the pan because the filter won't allow that to happen. He stated yes it would and no debris or clutch material would remain within the system. Those flushes are a waste of time and money especially if you have a drain plug in the pan. My recommendation is to take the pan down, change the filter, and refill the trans. It's very risky in my opinion to flush anything with over 100,000. When I was 16 (now 28) and worked at a Valvoline we would get cars back all of the time after high mileage flushes. The writers at my old GM dealership hate me because I would unsell the flushes on many cars and sell the customer a cheaper pan drop/filter change. On all of my cars and trucks I've installed a pan that has a drain plug or it already came with one. This way every 10,000 miles I drain and fill the transmission pan and by the recommended 50,000 I've almost tripled what a flush would do.
