What coolant are yall running?
1 Post
When i first bought the car i decided against dex cool and flushed the radiator out and have been running green since. Not sure anymore if its better, if it even matters, but there havent been any problems so.. What about yall?
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Dexcool has been great for me. I change it out every ~3 years, never had a problem.
Ive always stuck with Dex Cool since thats what GM calls for but Ive heard of several people switching it to green. And from what I hear nobody's ever had problems with either, just need to be sure you flush out whatever is in there before you switch
I had nothing but good things from dexcool. I honestly dont know why I switched, prolly so I didnt have to keep more then one type of coolant in the shop. Seems silly
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
1 Post
It only matters for people that never check or maintain their coolant. Dexcool gets gummy & icky, green stuff doesn't (that I've ever heard of or seen.)
I changed over to green when I replaced my water pump at 97xxx.
1 Post
Yeah I figured the stuff hadn't been flushed yet when I bought it at 83k. Just figure the green works for everything else why use dex. I had to refill my coolant today which is why I started thinking about it again. Do all the new chevys run dex now?
If you have any money into your engine ide use Evans coolant (Read up on it!) Its some bad as **** and keeps my twin turbo at 160 all day long in the hot summertime cruising
A bit exspensive though and never needs changed and doesnt mess with your rad or aluminum parts like other will
1 Post
Probably doesnt even matter, seems like mostly the same **** and nothing lasts for ever so your going to have to do radiator flushes every so often anyways. For those running dex still, just decided to keep GM recommendations or what?
