Wiring Questions
I have a 1946 Ford Pickup that will be using a LS1 out of a 1999 Firebird. When I picked up the engine/trans combo I also picked up the entire wiring harness from the Firebird... not just the engine harness, all the wiring in the car and I hope to use all of this for a smooth install into my truck. I also have the speedo, and steering column so I'm hoping that I won't have to do a VATS delete.
I won't be using cruise control, heater controls, AIR system and maybe some other odds and ends.
Can I just remove wires for the stuff listed above without any issues or would you recommend I just tuck that stuff out of the way?
