Will a 02 Vet LS1 drop into a 98 Z28
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Hello all, I have a 98 Z28 with a dead motor and looking to replace it. There is a local LS1 for sale for $2,000 with 50,000 miles pulled from a wrecked 2001 Corvette with no accessories.
1. Is that a good price
2. Will my 98 accessories bolt right on
3. will my 98 ECM and wire harness work as well
4. Is there anything that I am missing for a direct replacement
Thanks!
Thanks!
The price seems to be not to bad, not that great. I think it all should bolt up but you would have to possibly use your current intake system or do what is needed to get rid of the EGR system 01 & 02's don't have an EGR on the LS6 intake. You may have to have it tuned since the cams would not be the same. I am not an expert just my opinion.
You will have to change out the harmonic balancer/pulley because they are different than the F body, you will also have to use your sensors and stuff because they changed styles in late 99. I think you have a good deal going because you are getting a stronger motor.
So all accessories should bolt right on, and I can use my wiring harness? I am trying to figure out the easiest way with out having to convert this and replace that. LQ4\LQ9 6.0 sounds good to me. Thanks for the info!
Thanks for your info!
here..
lq9 short block= $500
ls6 heads=$300
ls6 intake=$300
cam=$300
injectors=$200
total=$1600
guaranty 400hp+
