How to determine interior color of 2002 Camaro?
I'm swapping out some interior parts from my M6 to A4 conversion and want to be sure I know what I need - I was under the assumption I had a graphite interior - somewhere between (light) gray and black. I figure there's a code on my driver's door sill that will tell me but I haven't had any luck in my search to figure out which one it is.
Pic of upper center console attached.
Thanks!
Thanks!
LS1Tech Administrator
Received 1,727 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Code 19I, Ebony.
This would be the same for all 2000-2002 models.
Strange that you have a "191", I can't find any info on that code at all. You can look up the codes and definitions for your VIN at this link, see if it says anything about a "191":
http://www.compnine.com/vid.php
My '02 Z28 shows a combo of 19I (interior trim, Ebony) and 19B (cloth interior, Ebony). I can see that yours has leather by the "192" code.
In any event, the center console is the same color for all the '00-'02 cars. It was different on the '99 and eariler cars though (Dark Gray, 14I).
