No MAF?
Cleaning it is a good idea, could help. How long is a little while? If you absolutely have to you can do it I am sure as the ECU will just use the VE table for fueling instead of the combination of the two but I would not do it for very long, pick up a used MAF on here for like $50, that's what I did a couple years ago.
Yea, I wouldn't drive around with it unplugged, have you tried cleaning it? And if you do drive around with it unplugged or bad I would def. drive it conservatively and stay off it
