supercharged 5.3 rebuild. help?
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Hey guys i have a 04 gmc sierra with a 5.3 Right now its torn all the way down to the block because i had a magna charger on it and wound up with some piston problems after about 70k. Im in the process of rebuilding the engine my self and have some questions about what route i should take. My cyclinder walls are scored in a few cyclinders so i have to bore it. The shop it was at already said it was sonic tested and passed. So my question is how far can i take it. I want to keep the blower and also was thinking heads and cam.?? any advice or ideas would be appreciated. Thanks.
so say i take it to a 3.905 with forged pistons and rods. then got the 243s i could still run the supercharger and it should be a screaming beast? Sorry if i seem i'll knowledged i know the basics just not the inner workings and the different combonations. But i know i have a engine with all the workings and i want to make a Beast of of it.
Okay heres my situation. Moneys not a huge issue because i have time. But its still not just a build my dream engine. the 5.3 block i have is already stripped down. been hot tanked and sonic tested, and checks good. My stock heads have already been cleaned and have had a valve job done to give them the 3 edge's. The block has to be bored due to scoreing in a few cylinders. So pistons are a must already. Its either scrap that block and go with the 6.0 start fresh. or continue to fix up the 5.3 and see what she'll do. Im at a loss because i dont know enough about what combo's do best here and what does best their. The only thing i do know is i wanna keep the magna charger on. I cant get away from the sound haha.
With what you will have in that 5.3 along with what you already have in it you could buy a 6.0. Then spend alil extra cam it and get forged pistons. Sell the 5.3. Get a set of tfs or trickflow heads for it and you will have a motor that will blow doors off cars. Call trickflow see what they recommend for heads for the 6.0 with the charger then call pat g for a cam. Dont be afraid to call these guys there the best of the best.
Hey, sorry to hear about the luck. Check out http://www.performancetrucks.net Tons of guys over there doing or thinking about doing what you are.
Im looking into the 6.0 right now to see how much i could get a block for. I wouldnt mind swapping over if i could get reasonable money for the 5.3 parts that wont be used so that its not a complete out of pocket build ya know. Seems how i already have money invested into the 5.3. What would it take it make the 5.3 "383 stroker" and then put the blower on that. Is that possible?
