Oil pressure sending unit?
I have a 98 SS with about 140,000 miles. Last time I drove it the oil pressure started randomly dropping. At times just cruising I'll hear a click and it will bottom out. The oil is fine and there are no other rattles/knocks or anything other than a cylinder missfire that I'm pretty sure is in-related. Could this be a oil pressure sending unit? If so is this an easy fix?
Im not sure if that is your problem, but if it is, the OPSU is a fairly easy fix. You do need to however pull the intake manifold off to get to it... as it is in the back of the engine. This may sound difficult if you've never done it... but after having to have to pull an IM 4 times already, I got it down to under 2 hours, tho my first time it took me over 4, but I was way careful. Its not hard and this could be a good time to swap to an LS6 IM!
If its true that you dont have ls6 intake then im with ^ him on pulling the intake.
I never had to change mine but heres a pic from uder the car when I had my trans out. See the yellow connector? The OPSU is the black cylinder looking thing standing straight up on the left of the yellow connector.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG-20110316-00150.jpg)
