Intake temperature?
Should I just get some high-heat paint?
Thanks
The only parts that might be suspect would be near the heads...basically, anything that isn't next to the incoming air paths. Being it's plastic it might be ok tho. I guess I don't know for sure, lol.
I measured my aluminum intake with a heat gun and running temp
was not too high - 130F maybe, I forget, posted the info here on
one of the subforums once.
Parked, it'll rise up to your ECT temp.
If you don't run your fans at lower than stock temps though, it
might cook a lot more.
