Help me decide on my next car.
You cant go wrong with the vette. It feels totally different driving than a f-body. Handles a lot better. As for performance at the drag strip, a stock LS1 C5 is pretty equal to a LS1 f-body.
The Z06 is obviously going to be faster.
The first day out at the track in my 02 Z06, I ran a best of 12.6 @ 112 bone stock with 30psi of air in the tires, full weight, and only made 3 passes.
The biggest down fall is the cost of modding them. If you're looking for a drag car, go with the f-body. If you want a fun street cruiser, C5. All day. I love mine.
At risk of starting some kind of argument, how in the hell is the f-body and the C5 equal on the strip? I would have guessed the C5 should be in the mid 12's.
I have been doin some research on the price of C5's. I wouldn't mind a high mile car with good interior. Like I said, the engine will be coming out anyway at some point. How is it to work on these things compared to an f-body?
To have somebody work on it for you? Polar opposites, ok i exaggerate but its safe to assume your going to fork over abit more jus cuz its a corvette c5 or c5z
Just to address this, mid 12's would be up there with LS2 C6 territory. But yeah, the F-Body and C5 are pretty damn close in a straight line, I mean they make the same exact power output, it's just the weight differences between the two that makes one a little faster than the other. The edge going to the Corvette of course, but I'd be willing to bet just one single bolt-on would probably put the F-Body over the edge.
LS1Tech Administrator
Received 1,685 Likes
Chances are it wouldn't be stock for very long. I guess I am just looking at it from a platform standpoint. I would like something that I can get to pull 1g in a skid pad, knock of some low 11's and cruise in to a little cruise in and chill. I am a little nervous about an IRS. I have NO experience with them at all. Don't know what to do with them or how to do it.
Also, what are some choice options to look out for? And the PIA's that only a C5 would have? I do like to pitch my cars in the corners and any kind of TC or TM would annoy me. I am not even a fan of ABS but its a give in with any modern car.
p.s. I am leaving here to go test the C5Z soon!
Vette specific parts are typically more expensive than f-body stuff. American Racing headers (awesome quality) cost about $1800 compared to pasesetter headers for f-bodies which are $350ish. My trans was a few hundred more than a f-body one...
My Z06 is an awesome street car. Drives like stock, is capable of running low 11's/10's on a good tire, isnt obnoxious, and will put you back in the seat. It WASNT cheap, but its nothing like anything else I've ever been in before. It handles great too.
If you buy a C5, it should be because you like that specific car. Otherwise, figure out which car it is you like, and spend the time and money modding said car to your liking.
#32
Remember when talking about straight line, you could likely get a better launch with the f-body's solid rear axle. This makes sense as the Corvette handles better with IRS. Kind of a trade off between the two cars. This would even the playing field at a drag strip though and make times almost identical, with a possible higher trap going to the vette because of less weight and better aero.
#33
Remember, you can still get an f-body to handle as good or better than a stock C5 with simple suspension mods, just that the C5 platform has better handling potential, especially on rough roads.
If you are still considering an f-body, look into a Watts link....it might be what you're looking for if you go that route (helps offset some of the SRA geometry drawbacks). With that, good shocks, sways, and a set of springs (if you so choose), it'll be a completely different car.
#38
I agree with why87.
How was the C5Z test drive???
#39
There is always a trade-off with engine modifications. I probably wouldn't buy a C5 at this point, but I WOULD buy a C6, likely with an LS3. It's a low 12 second, 115+ MPH car. Unless you spend lots of time at the track, there is little reason to do more than basic bolt-ons to a car like that. It's great to drive just as it is.
