Replace more than just water pump?
Needing some advice. My completely stock '99 m6 z28 needs a new water pump... at least I'm pretty sure. (symptoms.. huge waterfall of coolant in parking spot at work, filled, then nothing, then few days later a few drops, then nothing.. Im thinking its going to cut loose again soon enough).
Anyway I'm going to replace it and probably the thermostat while I'm at it. From what I can tell its going to be straight forward and fairly easy. What I'm seeking advice about is what all I should consider doing at the same time. It is a 13 year old car with 71k original miles. It has been maintained well and I want to treat it right.
Help me make a list?
Plugs / wires
Should I consider anything that goes out fairly common on these at 70-75k? Fuel pump or something crazy?
Of course I've already replaced my window motors on both doors (twice on driver side).
What brand should I get for the water pump? GM AC Delco or is the Autozone special alright?
I will continue to hunt through the boards for tips/tricks. Thank you for any thoughts/ideas!
Plugs / wires
I pulled my plugs on my 02 at 118K, and they were still good. Plug wires, on the other hand broke, so it was a good thing I bought a new set at the time.
I still have my original pump at 140K, but if yours is leaking, it needs to be replaced.
Are you sure it is leaking at the pump and not the radiator, hoses and or power steering cooler (if equipped)?
As mentioned above, I recommend replacing the belts and you should also get a new set of WP gaskets.
