why does my gas mileage suck!?
I used to get 28 or so per gallon on the interstate but now its hard for me to get 23 miles per gallon.
I really cant remember anything i have changed except for did plugs, wires, fuel filter...a few 1000's miles ago. I didnt remove the egr and stuff under the drivers front fender.....surely that didnt effect the gas that much or did it?
LS1Tech Premium Sponsor
How many miles on your current o2 sensors? What air filter are you running (and is it clean)?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
O2's? i dont know how many miles on them...I bought the car with 135000ish and I now have 197000ish and I havent changed the O2's or anything, I figured when they go bad the SES light would come on?
K/N filter and I keep it clean all the time along with the MAF.....tire pressure has stayed the same i always check that cause i do so much driving with my job.
With that many miles you need to replace your O2 sensors.
Check if you can feel exhaust pulses with your hand behind the tips, if you can then your cats are not clogged... if your cats were clogged you would see poor acceleration.
No, they're not "bad", they're still within the PCM's pass criterion even tho their response time has slowed down (they still allow the PCM to trim fuel, but because they have slowed down the PCM ends up adding a little too much fuel).
You have 2 front O2 sensors (used for closed loop trimming).
You have 2 rear O2 sensors (used for testing catalyst efficiency), you can leave these alone.
They something like $50 each or so.
and that could be the cause of killing 5mpg's or more ?
4? damn!
but once i put my headers on I will only be using 2? correct? I think when I had "frost" mail order tune, I cant remember if he turned off my rears or not.
but anyways, once i do the headers and ORY + tune, will i get some of my MPG back?
4? damn!
hmmm? well I cranked up first thing this morning and cold startup I figured the pulses would be pretty hard when checking. Ive got a Borla with NO plate and the exhaust pulses were not as hard as I thought they would be. I could feel them but almost was just a steady flow if that coming out. not hard though
Yes, your O2 sensors need replaced BEFORE the SES light comes on! They have something like a 50-60K mile service period!
__________________
