General LSX Automobile Discussion Non-technical LSX related topics.
Engine Mount
Old Jan 2, 2013 | 09:20 PM
Gordon0652's Avatar
Hello,
Looking into engine mounts for my current F-body build. I would like to stay away from solid mounts. I bough poly mounts and did not realize that they use the factory metal casing. I am somewhat against that.
Is there any other options? Thanks.
Old Jan 3, 2013 | 08:35 PM
jbridwelltransam's Avatar
factory replace, solids, or polys are your only options bud
Old Jan 6, 2013 | 09:10 PM
99Bluz28's Avatar
Nope, no other option with poly mounts. You'll have drill out(or grind off) the rivets like everyone else.
Old Jan 7, 2013 | 10:40 AM
Mumbles's Avatar
As stated, there are three choices. Upgrading the bushings within the factory Clamshells is pretty straight forward. What makes you "somewhat against" this setup?
Old Jan 7, 2013 | 11:25 AM
Gordon0652's Avatar
I was just hoping someone offered something else than the factory clam shell.
Old Jan 7, 2013 | 02:39 PM
lees02WS6's Avatar
I just took my poly motor mounts off, swapped back to rubber.
Old Jan 7, 2013 | 05:47 PM
99Bluz28's Avatar
Why...?
Old Jan 7, 2013 | 06:25 PM
Coy's Avatar
Coy
They do. Solid mounts.
They aren't so bad in an M6 car. I wouldn't ever do it again though unless it was for a race build.
Old Jan 7, 2013 | 06:26 PM
lees02WS6's Avatar
Originally Posted by 99Bluz28
Why...?
Don't like the added vibration, the additional flex in the rubber also helped me get the drive line angle I needed.
Old Jan 8, 2013 | 09:03 PM
sickpony's Avatar
I used the energy susp polys too. It does seem wierd that you have to use your old clamshell housings but not that big of a deal. I'm happy with them.
Old Jan 9, 2013 | 08:15 AM
Apparently there is some halfway ghetto thing people are doing. Putting urethane windshield sealant around the stock rubber in the mounts and letting it harden. Has anyone here tried that?
Old Jan 9, 2013 | 10:46 AM
Coy's Avatar
Coy
Any links to somebody who has done that? Aircraft panel/seam sealant would work great for something like this, but I am not sure how well it would bond to the rubber, and it would definitely stand up to the heat considering we use it for engine nacelle panels. Sounds ghetto, but if it works and wasn't as extreme feeling as a solid mount (I had Spohn solids in two cars) or transmitted vibrations like poly mounts it might be worth a shot. Worst case scenario, you scrape it out and install rubber or poly.
Old Jan 9, 2013 | 11:12 AM
I've not seen it done on f bodies, just some guy on a 240 forum mentioned doing it. Be a pioneer and do it man! I'm doing mounts in my car soon but I will not be making the effort twice to take them out, urethane them, test them then either keep them or install my polys.
Plus it would be best to do it with new rubber mounts because it is already in the correct position, once they wear they start to jostle around and it would be difficult to get it to fit right.
Old Jan 9, 2013 | 04:15 PM
Coy's Avatar
Coy
I don't have enough down time with school and work, and my car's current mounts are still fairly solid. It was just a thought.
Old Jan 11, 2013 | 06:15 PM
99Bluz28's Avatar
You can buy liquid urethane kits just for that purpose.
http://www.energysuspensionparts.com...sp?prod=DIYMMI
Old Jan 12, 2013 | 12:03 PM
Ah nice! Might be worth a shot to some!
Once I get my poly's on if I don't like them, i'll be going this route
Old Jan 12, 2013 | 06:57 PM
Orange Juice's Avatar
I swapped back to the stock rubber also just to get rid of the vibration. I don't think using the stock clamshells again is a problem just make sure that the rivits are replaced with bolts.
Old Jan 14, 2013 | 07:38 AM
Sierra Speed Shop's Avatar
Is there a demand for aftermarket clam-shells for the engine mounts? We can manufacture it if the product makes sense.
Old Jan 14, 2013 | 12:07 PM
99Bluz28's Avatar
Believe it or not the poly engine mounts transfer very little additional vibration, it's the poly trans mount that's normally the culprit.
Old Jan 14, 2013 | 03:43 PM
Thank you 99Bluz because these people were getting me scared lol. I might try to tackle the installation this weekend.
