I'm getting conflicting info on VIN decoders - PLEASE HELP!!!
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
some are telling me that this is a LS1 and other are saying it's a 6 banger. Can someone please tell me what motor and trans this VIN correlates to. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
VIN: 2G2FV22G7W2221494
Thanks!!!
Thanks!!!
LS1Tech Administrator
Received 1,727 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
8th digit = "G".
G = LS1 for a 4th gen F-body.
Any decoder that tells you otherwise is wrong.
W = 1998
Nothing about the VIN specifies trans type. However, you can run the VIN through compnine.com or contact any GM dealer and ask for a VIS report on that specific VIN. It should contain all RPOs associated with that VIN number, and thus you can determine trans type.
RPOs "MN6 & MM6" = manual T56
RPOs "MX0 & M30" = auto 4L60E
NAPA CATALOG INFORMATION
Vehicle Type: Automobile/Light Trucks
Year: 1998
Make: Pontiac
Model: Firebird
Engine: 5.7 L 346 CID V8
VEHICLE INFORMATION
Country: CANADA
Vehicle Type: Passenger Car
Year: 1998
Make: Pontiac
Model: Firebird
Engine Type: V8, 5.7L; SFI
Assy. Plant St.Therese
Production Seq. Number: 221494
Body Type: 2 Door Coupe
Trim Level: Formula; Trans Am
Driveline Type: RWD
Restraint System: Dual Air Bag; Manual Belts
Vehicle Class: Small Car
Fuel Type: Gasoline
Manufacturer: General Motors Corporation
Engine Code: G
Year: 1998
Make: Pontiac
Model: Firebird
VEHICLE INFORMATION
Country: CANADA
Year: 1998
Make: Pontiac
Model: Firebird
Driveline Type: RWD
Fuel Type: Gasoline
Engine Code: G
That vin decodes to an auto car with 3.23's not 2.73's
142 = TRIM COMBINATION LEATHER, LT GRAY LEATHER TRIM(142)
14I = INTERIOR TRIM LT GRAY INTERIOR TRIM COLOR(14I)
1SA = PACKAGE-OPTION 01 (1SA)
6ZM = COMPONENT FRT LH COMPUTER SEL SUSP (6ZM) SUSP(6ZM)
7ZM = COMPONENT FRT RH COMPUTER SEL SUSP (7ZM) SUSP(7ZM)
81U = EXTERIOR COLOR,PRIMARY EXT COLOR(81U)
8TH = COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
9TH = COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
A31 = WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
AAA
AG1 = ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 = RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AQ9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AU0 = LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 = LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
C60 = AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
CC1 = ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
DE4 = SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
DG7 = MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 = DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE2 = SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
FE9 = FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
G80 = AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
GU5 = AXLE,REAR,3.23 RATIO 3.23R(GU5)
IL2 = TRIM,INTERIOR DESIGN INTERIOR TRIM DESIGN(IL2)
J65 = BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K43 = GENERATOR 102 AMP 102 AMP(K43)
LS1 = ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
M30 = TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD AUTO TRANS(M30)
MX0 = TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) AUTO TRANS PROVISIONS(MX0)
NF2 = EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5 = STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NW9 = TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
PA6 = WHEEL,STYLED(PAINTED) STYLED PAINTED WHL(PA6)
QLC = TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
R6J
R7X
STE = PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
T43 = SPOILER,REAR RR SPLR(T43)
T78 = HEADLAMPS CONTROL DELETE T78)
U75 = ANTENNA,POWER(CHROME) PWR ANT(U75)
UA6 = THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UB3 = CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 = CONTROL STEERING WHEEL,ACCESSORY STEERING WHEEL ACSRY CONTROLS(UK3)
V73 = VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
VM3 = LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
W55 = ENTERTAINMENT SYSTEM OPYION E ENTERTAINMENT SYS OPT E(W55)
WS9 = MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
Y82 = TRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
AAA
R6J
R7X
(Snipped out the rest of the post.)
I would like to compliment you on your very first post here being correct.
Yes, but you don't get 2.73's in an auto TA with the limited slip tranny, you get 3.23.
2.73's were the typical gears for the auto V-6 without the limited slip rear. There are other combinations possible, I had 3.42's in a V-6 with the Thorsen rear that came with the performance package.
But in this case it appears that the LS1Tech VIN decoder is just wrong.
For Z28, Formula (non-WS6) and Trans Am, you could have either 2.73 or 3.23 (extra cost) with the auto trans.
Limited slip (G80) was standard on all LS1 F-bodies.
You most definitely could get 2.73s (GU2) with a limited slip differential (G80) in an LS1 Trans Am. In fact, 2.73s were the standard gear for all 4L60E (MX0/M30) LS1 F-bodies. 3.23s (GU5) were the optional "performance" axle ratio for the auto trans, and were a required option when WU6 (Firehawk), WU8 (SS), or WS6 was selected with an auto trans.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
