Low Idle Oil Pressure?
I notice this once in a while with my car, a stock LS1, when I drive it around for a while and it gets hot. I'll notice my pressure drop below 40 (around 30-35psi). Imo seems normal, I run 10w-30 in my motor.
As the motor runs hotter the oil thins out so it makes sense if the pressure runs a bit lower at idle. The most important thing is that thw pressure goes as normal with your driving i.e. 60-80psi at WOT, 30-40ish psi with normal driving.
