LS6 Cam in 6.0 - New pushrods???
The higher lift LS6 cam has a smaller base circle. GM made the valves .0236" longer to give the proper preload with the production length (7.385") pushrod. IIWY I'd run .080" wall 7.4" long pushrods with .045" thick Cometic head gaskets as well as have the heads surfaced .010". Are you running corresponding LS6 (yellow or blue) valvesprings ????
