More cubes= slower car
Sounds like we are still talking about different cars with different (unknown) suspension/chassis/drivetrain [trans/gears/stall] setups. Too many variables to look at displacement as the main factor of win/loss.
Even a "lazy" 408 LS build (stock head castings warmed over, mildish cam, stockish compression) will make more power/torque than a "stock" 5.3, and will accelerate faster in the same car with equally well matched drivetrain (trans/gears/stall) for the respective powerband. I'm not sure where you are going with this, unless you're talking about an internally stock 5.3 + boost vs. a 408 NA build, but at that point the 5.3L has an artificial displacement increase (boost). If the drivetrains and chassis are not equally optimized respective to the engines, then yes it's entirely possible for the smaller cube engine to accelerate the vehicle faster. But then you're not really comparing displacement any more, but rather how well optimized each vehicle is to it's respective engine.
Lets be fair, I Showed GTR's Supras, vettes Etc. yes, weight,gearing etc are all Variables. but if you are building two identical cars except motor sizes and when I say identical.... I mean same car making the same Power. then gearing will not stay the same, the one with the smaller motor would TYPICALLY require a tighter Final drive. And a smaller A/r on the Turbo. so to be fair, they would never really be identical.
Now with that said. Shouldn't the output difference be obvious in the cars' performance? I will ask another way:
1krwhp 408TT
Versus
1krwhp 5.3L or 2jz or whatever (geared properly)
Would you expect the latter to win or lose in most races?
1krwhp 408TT
Versus
Not that I agree with op. But there seems to be alot of under performing larger engines. This is why I tell guys there is no reason for internal mods on LS cars until they get well into the 11's.
LS1Tech Administrator
Received 1,685 Likes
There is also the matter of optimizing each respective engine; "lazy" vs. "max effort" in this category as well, plus all points inbetween. If the smaller cubed engine is a more aggressive build with a window of higher power/torque (as compared to a less aggressive bigger cube version), and then the rest of the drivetrain is optimized to keep that smaller cubed, hotter engine in that specific window, then I would expect it to be faster.
Again, lots of factors to look at here.
Lol are you serious? Look at the power to weight ratios that is a huge factor then the next biggest factor imo is gearing and then the set up over all. If a tt 408 or any big block thats properly built (key word properly built) should make 1k plus hp n trq. Im not dissing the 2JZ but i promise you it will never be able to match what a 572, 632, 454, hell even a 408 can make when properly built more cubes means more power you can make. That 2JZ can make stupid power and last for what it is. The major advantage it also has over the bigger engines is less rotational mass ( im assuming because it would use a shorter crank and cams, please correct me if im wrong) which helps a lot. But you can have all the power in the world but if its not built right or hooking up you will lose
RPMWS6. I think you are right, it makes sense. but why is it most of these guys dont optimize their setups? clearly Im not the only one that noticed, there is a guy in this thread that said the same thing. Im currently still not sure what motor to get for my build. I would hate to be one of "those" guys.
You really should have waited for page two to comment, we kinda touched on that already, but just so you know. the crank,six rods/pistons in a 2jz are heavier than the 8 in an LS motor. and the crank is also a lot longer. its not a v6, its an Inline 6. there is more rotating weight in a 2jz than an LS.
I understand what you are trying to say, but like a few others, I do not fully agree with it. There are good and bad combos all around and quite a few mismatched and thrown together builds too.
That is why there are professionals though. To help weed out the weak points and issues you may have. If you spend a chunk on an engine you should very well get your moneys worth...but that works in the opposite direction also...quite often you get what you pay for.
I posted this on a Supra board and got a reply I am content with..
You need to consider several things. Your only taking into consideration the HP which is estimate. Remember almost every dyno will read slightly different. Some dynos read completely different and others that are calibrated manually can be WAY off. A dyno is a tool to measure progress from a tune and was never intended to measure ***** size.
Aside form that, again power band is another huge factor, as well as aerodynamics, weight of the vehicle and the gear ratios in the rear. Just because its the same trans does not mean that it has the same rear end. Even tires need to be considered as something with a larger contact patch and softer compound will have a inherently higher drag coefficient than say a full pressurized street tire. Far too many variable to consider. All else aside though, if they were the same crank power and same power band/gear/aero/weight etc there would be no difference. One car has a clear underlying advantage in the situation your expressing."
This comparison would be a lot easier to analyze if the only people that raced were the ones with perfectly optimized setups. Unfortunately, we don't live in that world. So you get a lot of partial builds running out there making the big cubes look bad - people who are building toward a forced induction/nitrous build but only have the low compression heads/cam/pistons in the block currently, etc.
#32
MPG and octane requirements, ride quality, off-idle acceleration, general streetability, longevity of components, intended range of operating conditions, available cash, etc., are all reasons why someone may not want a "max effort" build for a given application. Larger displacement often makes an engine more fun to drive on the street at typical street rpm ranges, but depending on the degree to which the engine (and rest of the car) is optimized for racing, it may or may not make it faster at the track. Conversely, the faster car at the track may or may not be more fun to drive on the street (and much of that is personal preference as well).
#33
Find a 408-427 with a set of all pro heads or something along the same line with enough turbo exhaust housing and wheel flow. It will be a monster as long as the rt of the car is setup correctly. But someone that knows how to setup the motor and turbo efficiently will probably have there chassis in line also. If your running marginal to good heads the smaller cubes will shine. Big cubes need a large bore to feed them along with stellar heads and then enough turbo to keep it all efficient. This is why a 370 works so well for alot of people because a set of afr or trickflow heads can feed them very well. It's about the system as a whole not any peice or 2.
#34
Acceleration is all based on your setup. On turbo applications the more lag you have the slower your acceleration will be. I do not see your statement or observation being true on a properly setup vehicle.
