Mods to get the most hp from stock ls1 block?
right now im looking at ;
lid
long tube headers
true duals out the back
CAI
ls6 intake or FAST intake
ported tb
ported ls6 heads/tfs 215/prc 215 *one of those
UD crank pulley
gears
tune
ms3/ms4 or other large cam
what other members have added to my list:
upgraded maf
upgrade fuel injectors
lid
long tube headers
CAI
ported tb
UD crank pulley
gears
tune
upgraded maf
You wont get the "most power" from a donkey dick cam. You will get it from the proper cam.
You will need an upgraded fuel pump and injectors and a new oil pump and chain if you are going to wring it out hard.
The truck maf can help, but we also have a custom 4" kit with a card style maf that will work well beyond the truck maf's capabilities.
And we offer the option for custom tunes etc. You will likely need alot better idea than just "gears". That 10 bolt wont hold up long. If you use a rear end girdle and HD gears MAYBE. But still borrowed time.
Next up is the clutch. You will need a rather harsh clutch for a single disc OR you can go with the mcleod twin disc RST and be golden for anything you do to the stock LS1.
dont forget 160* t stat
And ditch the alum driveshaft. It will likely wad up when you launch under too much power.
Then you will be looking at suspension. You should prob do suspension in conjunction with all of that really. In the rear at least.
and that will also depend on if i want to go with a 12bolt or 9"
I would go with the 12 bolt. We have a good price on them. But everyone else will sway you toward the 9". But remember, the 9" will eat up more power....so there goes the idea of this thread too...
http://texas-speed.com/c-109-370-408...ng-blocks.aspx
http://texas-speed.com/c-47-cylinder...urerFilterID=0
STRANGE also has custom Chrome-Moly driveshafts for just a shade over $300 !
#34
lid
long tube headers
CAI
ported tb
UD crank pulley
gears
tune
upgraded maf
lid
long tube headers
CAI
ported tb
UD crank pulley
gears
tune
upgraded maf
