Lets clear up which weighs more, 4th gen LS camaro vs TA
#43
LS1Tech Administrator
Received 1,685 Likes
I noticed that the compound my OEM WS6 hood was made from seemed to be quite a bit heavier than the typical "light weight" aftermarket fiberglass hoods. I'm sure they are still lighter than the steel hoods, but probably not a drastic difference. Anyway, the additional weight of the 17x9" wheels and 275mm tires offsets some of the weight lost by the hood, so it's probably close to equal between a WS6 T/A and base T/A.
#44
#45
2 car & driver articles 3-98 trans am firehawk 98 curb weight 3520 lbs also 8-99 article compares verts SS camaro 3574 vs trans am 3617 lbs. i hope that helps cheers! one more 2-99 a 1999 camaro z28 weighed in at 3443 lbs.
