How to: Winter Storage in Minnesota!
While it is definitely important to get the oil hot enough to burn off condensation if you're going to start the engine, hence why simple idling is not advisable, there is another issue to consider in this regard as well.
A typical street engine sees greatest wear during a cold start, especially a cold weather cold start. Even a 0w oil will not provide optimal flow when a cold engine is first started in very cold weather. With this in mind, I see little reason to do a bunch of cold weather cold starts just to let the engine idle. Winter storage is around ~6 months or less, and this sort of short-term sitting has never harmed any engine that I have done this with (SBCs, LS1s, 3.8Ls, etc.) My opinion is to just let them sit, but if you do have the opportunity to actually drive the car then, as mentioned above, running a heater for a bit to warm the oil pan area wouldn't be a bad idea prior to firing the engine.
Location: Illinois, as close to "Normal" as I can get...
Sea Foam is a fuel stabilizer too and has a longer shelf life than Stabil.
I use it in everything that gets stored over the winter, lawn mower, weed wacker, leaf blower and put some in each gas can I have in the shed.
if a valve spring breaks dont blame a fellow minnesotan. cheers. people in canada & alaska start their cars all the time when its 20, 30 below! just sayn. ps i may not have 10k posts but i have driven 2 vehicles over 200 thousand miles in minnesota so i think i know alittle about taking care of my cars.
While most people advise a full tank of gas, i drain the thing down as far as it will go and let it sit.
Fuel quality today is FAR less than it was 5 years ago. We've had gas sitting in a vehicle go bad in just 2 months. The way I see it, there is no reason to pump that nasty fuel through your injectors and fuel system, and definitely not 16+ gallons of it after sitting for 6 months.
I fire up in the spring and load the tank with fresh 91 and drive it around. Haven't had any issues since I owned the car doing it this way.
I'm going to rest easier this year with it in a heated garage.
Good luck OP
Good luck OP
LS1Tech Administrator
Received 1,792 Likes
As said above, Sea Foam is another option, but I've had great results from Stabil. It lasts on the shelf for up to two years after the bottle has been opened, but mine never sits around that long anyway since I use it with every fill-up in my garage queens (they sit a lot even during the on-season.)
The entire fuel system in my '98 is still assembly-line original, and even after sitting for months the engine will fire up as though it had been started yesterday. Fuel stabilizers are an excellent way to prevent most of the fuel system issues that people see in stored or seldom used cars. As another point of reference, I've recently had the Holley on my SBC apart and the inside still looks like brand new (hasn't ever been rebuilt and was manufactured in 2008). This car sits a lot, and always receives E10 fuel + Stabil.....which seems to be working great.
Ultimately, it's less about what damages or doesn't damage the engine, since nothing discussed here is going to be an instant death sentence, but rather what causes the least amount of wear, or wear vs. benefit.
Pontiacerator
And, as a matter proportion, what is the safe time window for letting a car sit? 6 months? A year? 3 years? 10 years? We all know the hazards of buying a car that has sat for extended periods.
The old school rule is that cars are meant to be driven, and they deteriorate when they are not. Admittedly, I'm thinking in terms of the 60's, but wheel cylinder seals, master cylinder seals, valve cover gaskets, etc. etc. dry up and go bad when not kept in frequent use.
My 69 Judge engine rebuild had 11 years and about 4k miles on it when the rear main seal started leaking (on a traditional Pontiac, you have to pull the engine to replace it). Would it have lasted longer if I drove it less often but for longer periods? Or if I drove 10k a year?
I admit I'm old school. But that's my point and I'm sticking to it (until convinced otherwise). I try to drive my non-DD cars as often as I can, weather permitting.
I think the idea that seldom-used cars will "rot away" comes from the fact that many people who don't drive their cars regularly also don't maintain them properly for their roles. For example, I've encountered some people who seem to think that coolant rarely needs to be changed if the car is seldom driven, and then they end up with rotted heat cores and radiators. And now this person thinks that sitting was the problem, when in reality it was the lack of proper fluid maintenance.
As a side note, I think cars stored outside don't hold up as well as their indoor counterparts (meaning more than just cosmetics). Temp and humidity changes are more frequent and rapid, and moisture from rain tends to work it's way into things even if the car is covered. I am less confident about durability when it comes to long term outdoor storage in harsh climates, not specifically about the engine but rather the entire car (brakes will rust/lock-up, etc.)
i am in cleveland ohio if you guys want to talk rust, calcium chloride and salt, ground cinder used here ,all are roads are literally white after a snow storm. trucks that are not even 3-4 years old showing rust already, i park mine for 6 months and dont even look at it, remove the battery and fill the tank. mind you the temp here does not get crazy, but a few below 0 days and mostly 10-30's degrees here through the winter. all though i am not **** about my car as i should be.
#32
I just happened across these: http://www.carcoonusa.com/#!services1/c205t
Pretty slick if you garage park during winter and they seem affordable.
#33
Pontiacerator
The longest I have ever gone is 7 years. This was with a '76 Eldorado/500ci engine, with over 110k miles on it at the time. Frankly, it wasn't properly prepped for storage (belonged to a relative) and had basically just been parked in a garage in October of 2000 (not driveable due to brake line rupture) and then not run or moved until September of 2007. Surprisingly, with some fresh gas it fired up and ran just fine and was driven regularly by the friend I sold it to for a year before he put it back in storage.
#34
Hi all,
I know this seems pretty far away, but if you live in Minnesota you are probably already thinking of it.. dare I say it: The Winter! Yes..snow, ice, freezing temperatures and not being able to drive your nice little sports car - AT ALL (for about 6 months).
Questions:
1. Tips on storing my 2002 Camaro z28 in an outdoor garage with no heat?
2. Should I run the car periodically to keep the fluid flowing?
4. Any product to use when storing it during the winter in freezing cold temperatures?
3. The temperature outside/in the garage can literally drop down to -20 to -30 degrees farenheit - If the car had condensation from running it periodically, would it freeze and cause problems?
4. Any misc information, tips, or comments about what YOU guys do when storing your car for a VERY long, cold winter?
Thanks!!!
Questions:
Thanks!!!
#36
For what it is worth, my car had no leaks when I got it in the spring of 2012. I have no garage. It sat outside from December to early March 2013, which was a mild winter, and in that time the battery went dead and the rear main started leaking a little bit.
Spring 2013 I put a charger on the battery on a whim and after about 4 hours it started to take a charge. It worked all summer surprisingly. Rear main still leaks slightly. No other bad things happened that I could find.
Winter 2013-2014 it sat outside again, this time from October to mid March. It was far colder, harsher, longer... just brutal. Subzero quite a bit, tons of snow, the works. Weird thing is it didn't seem to faze it at all. Battery didn't die this time, no new leaks, nothing. I call that the zombie battery now.
The only real prep I ever did both times was put fuel stabilizer in the tank, fill it full with premium, drive it home, and park it. I had crap tires that I didn't care about flat spotting. In the spring I start it up and let it idle up to full operating temp while I check/fill tires, check for leaks, etc. First time I drive it I go more carefully to make sure things are moving and all OK before getting on it at all.
This November I'm getting a house with a garage, so that will be nice. I replaced the wheels and tires this spring but kept the junk ones just for the winter storage.
I agree with the idea of just letting it sit vs starting it in cold weather. My car is cammed, and it is grumpy when it is in the 30s, and sounds downright awful on a cold start below 30 with how much it gags and sputters. It isn't even that aggressive of a cam either. That really unstable RPM can't be good for getting oil moving properly, so just avoid it IMO.
