Back fire/popping
Hello all, haven't posted in a while. My car has always popped a little through the exhaust but its been doing its very badly lately. I was on my way to a car show last weekend and passed someone. I got around the person and was slowing back down and the car backfired. Horribly. I got home from the car show and parked it in the garage and let it idle and then slowly revved it up, once it got around 1600ish rpms it started popping/backfiring/miss firing horribly. Any ideas as to what it is? Or what it could be? Bad knock sensor? Or bad coils/wires?
There are a million things that could cause a misfire.... And you have provided little to no info about your car. First scan for codes and see if that can point you in the right direction. If theres no codes then start with plugs and wires, then check coils and O2 sensors. Those are pretty common, but theres tons of other things that could cause it as well.
Picked one up for catalyst system below threshold or something like that. I was wondering about plugs/wires/coils.
Yeah, mine has always popped a little, but seems to have gotten worse sine ive owned it. It will even pop in 6th gear at 1400 rpm. Quite annoying
