03 Silverado Ss
Everything else will swap over and bolt right up.
Use the truck oil pan and front drive accessories and crank pulley.
So if I pull the crank and have a 24 tooth reluctor wheel pressed on what do I need to do to fix the cam situation from 1x to 4x? And the Ls2 is out of a trailblazer Ss is this what I would need to go from the 1x to a 4x cam issue
https://www.texas-speed.com/p-3969-g...-reluctor.aspx
You could have the 24 tooth put on yes and you would need a 1x cam gear. The LS2 should already have 4x, your pcm in your 03 truck was setup to read a 24x crank and 1x cam
you have 58x and 4x on the LS2
Call texas speed and tell them what you're doing and they'll hook you up with what you need. Or try WS6store
