Fast lsxrt intake and fuel rail help.
Does anyone know the correct FAST part number for a fuel crossover line that will work with the FAST LSXRT truck intake manifold and FAST fuel rails that have the 8an fitting for the fuel crossover line? I ordered the one from FAST that was recommended with there fuel rail kit and LSXRT 102 mm. intake, however it is to short at 12 inches and wont fit around the back or over the top of the intake. If you try to run it around the front it will be in the way of the throttle body. I am not impressed with FAST at this point. Oh and their directions are horrible by the way. Any help you guys can provide would be much appreciated!
Just make your own. I ordered a foot of fuel line and some AN fittings. Took all of 5 min to make. Not hard at all and you can route it how you want. I put mine in the back to clean up the front. You can see it in the back. Hard to see since the firewall is black, but you get the idea.
![](http://i64.tinypic.com/ndwysj.jpg)
