Soft clutch at high rpm
having issues with my 02 ws6. I just had the entire transmission rebuilt and the clutch is still sticking to the floor around 5500-6000 rpm. Anyone know why?
Install this if its not in the car already.
http://www.tickperformance.com/tick-...-firebird-ls1/
problem solved.
problem solved.
You didn't have your trans rebuilt for this issue did you? If so you just wasted some serious money, should have searched on here as this is a common problem with the stock master cylinder.
