LS6 cam-HELP on deciding
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/cam_spec_85a15eff37ee37ed35ec321165ed4e09b58a24b3.jpg)
Hi:
I'm new to the forum and I was wondering if I can get some feedback on this CAM. It has been siting in my Garage for over a year but I never used it as I'm not sure what the specs means. I plan on building my LS6 motor, no plan of using NOS or Boost, and mainly street would this be a good cam to use? if so do I need to make any upgrades to the top end, springs, Pushrod's, etc??
Any help would be well appreciated..
Thanks in Advance..
Hi:
Thanks in Advance..
Objective comments - people use 224/234 size comes in LS motors and bigger. The ramp rate appears slow compared to a Comp XE cam of the same size. The lift is fairly mild at ~ .566, I would want to a new valve spring kit with new retainers, locks etc. Aftermarket push rods. You will need to measure. The 111 LSA and 108 center line are tighter than most of the typical LS cams. This looks more like a carb cam to me at first look.
Someone else will have to examine the valve events.
