General LSX Automobile Discussion Non-technical LSX related topics.
Documenting my first 5.3 to iron 5.7 LS build
Old 10-21-2018, 03:48 PM
  #41
Underachieved's Avatar
Default Removed broken manifold bolts.
Sunday funday. All 3 broken Manifold header bolts removed. Might have to helicoil one of the threads or figure out something different. Bottom assembly going to the shop to get balanced tomorrow. Practiced alot of my darker vocabulary today!
Old 10-21-2018, 05:24 PM
  #42
LS1Tech Premium Sponsor
tech@WS6store's Avatar
Sometimes bolts need a blue wrench and sometimes you need to turn the air blue, its called balance
Old 10-21-2018, 06:27 PM
  #43
Pain in the **** either way. But over now. Going to get my gasket list all ready. I imagine it will take a week or so at the machine shop. Thanks for all your help.
Old 10-22-2018, 04:23 PM
  #44
I need to get OEM rod and crank bolts. I will be on #3 x's torqueing these down (factory 1, pre assembly 2, final assembly 3) and would like to get new stock bolts. All I can find is new versions that claim stronger clamping but this might be an issue since I already have clearance done.
Old 11-01-2018, 03:42 PM
  #45
Default Heads back from getting cleaned.
A few shots of the heads after getting cleaned up and Heli coil installed in one hole. Next will be some mild porting. Not sure if I plan on going bigger valves at this time. Balance should be complete next week so I am excited to get this buttoned up for the winter.
Manifold bolt hole fixed on the left.
Old 11-01-2018, 05:25 PM
  #46
We have larger stainless LEADFOOT valves for half the price of the other guys too
Old 11-01-2018, 09:48 PM
  #47
BLK95-Z's Avatar
I've heard that installing the larger 2" intake valves is only good for another 6-7 cfm unless you plan to de-shroud the chamber some around the valve. Just something to keep i mind.
Old 11-03-2018, 04:10 PM
  #48
Default Balanced assembly is back
Machine shop said that everything was pretty close. He was even suprised.
I pre assembled the Mains to check crank clearances with some platigage.
1,2,4,5= .0015,
3=.001-.0015
I am pretty happy with that.
Old 11-03-2018, 04:13 PM
  #49
Machine shop was rather pricey on doing the valve work for 2". I think I will wait until the bottom end is complete and revisit my head options.
Old 11-03-2018, 04:39 PM
  #50
Full vj at our local shop is 240ish. But thats with cutting used valves. havent checked new.
Old 11-03-2018, 05:20 PM
  #51
Local as in?
Old 11-03-2018, 06:05 PM
  #52
As in the machine shop i take alot of parts/blocks/heads to to get machined.
Old 11-03-2018, 06:57 PM
  #53
I should have been more specific. Local as in Iowa?
Old 11-03-2018, 08:00 PM
  #54
Correct
Old 04-11-2019, 07:36 PM
  #55
What is the secret to install pistons? I am have trouble getting it to work. The oiler ring assembly wont got in. I bought the compressor from amazon. Is there a better way or better product?
Old 04-12-2019, 01:49 AM
  #56
Pic of installer?
I personally like and use 2. Either the band style (you can rent from local parts store for like $12) and the tapered ring. The style with the pliers are pretty hard to handle and i dont like them.
Old 04-12-2019, 05:46 PM
  #57
see attached
Old 04-12-2019, 07:30 PM
  #58
cookseyb's Avatar
makes affordable tapered ring installers, they work best for me..
Old 04-12-2019, 07:34 PM
  #59
Who makes?
Old 04-13-2019, 08:17 PM
  #60
cookseyb's Avatar
Wiceco, ARP look at Summit or Jegs they have them...
