General LSX Automobile Discussion Non-technical LSX related topics.
water
Old Apr 24, 2019 | 01:06 PM
thunderchickentoo's Avatar
Default water
So I had number 6 cylinder full of fresh water, hydrologiced broke starter. Cannot figure out how water got in the cylinder.??2000 Formula Firebird
Old Apr 24, 2019 | 07:37 PM
B52bombardier1's Avatar
Are you running plain water in your radiator? If yes, I predict blown head gasket.
Rick
Old Apr 24, 2019 | 09:43 PM
Default no antifreeze
Rick
Anti freeze, new that was comming, tasted the water, clean water, not even smelling gassy like gasoline mixed from tank?? Seems this year is weird car issues
Old Apr 24, 2019 | 09:52 PM
LLLosingit's Avatar
Seen many posts where when it rains water leaks down the cowl onto the top on the engine and then leaks into the engine via the loose seals on the intake.
Example thread 1
Example 2
Example 3
And another
Old Apr 24, 2019 | 11:11 PM
Default Thanks
Example thread 1
Example 2
Example 3
And another
Makes sense, parked under a tree in Fl, heavy rain I hadn't started it for a few weeks, then bango when I cranked it over. Odd it only filled one cylinder though. Will have to keep it out of the rain
Old Apr 25, 2019 | 08:02 PM
Utinator's Avatar
The water drips off the cowl, and onto the intake manifold. From there, it runs down and collects around the #6 injector. If the injector seals don't keep it out, the cylinder will fill with water.
I tried to silicone the cowl, where it overlaps in the middle. I don't think it stopped all the water seepage though. I do have new-ish injectors with new seals. I'm hoping that keeps my engine alive.
Old Apr 25, 2019 | 08:18 PM
Default water
Drained cylinder replaced all injectors, new o rings spark plugs oil and filter new starter, so far so good makes me paranoid to get it out in the rain
Old Apr 25, 2019 | 09:10 PM
LLLosingit's Avatar
It's not a problem when it's running unless you drive through deep water. What drips from the cowl isn't an issue unless the car is sitting, A running engine would burn off the water.
Old Apr 26, 2019 | 10:32 AM
bammax's Avatar
You're lucky you didn't snap a rod. I'm guessing there was just enough water to ruin combustion but not enough to fully compress. You should buy a lottery ticket lol
Old Apr 26, 2019 | 02:37 PM
Utinator's Avatar
I just had a thought. I wonder if plumber's putty would stop the water from getting to the #6 injector...Ex: you could make a circle "dam" around the injector with the putty. The LS6 intake already has a small raised circle of plastic around it. It seems to keep some water out. I'm not sure if the LS1 intake manifold does or not. Does anyone have close-up photos of the LS1 intake injector port?
Old Apr 26, 2019 | 08:29 PM
warriorpluto's Avatar
Im thinking, would a corvette engine cover keep most of the water off of the intake? Maybe someone can design a cover that protects from water intrusion.
Old Apr 27, 2019 | 07:41 AM
Utinator's Avatar
Nope. I already tried that. The cover doesn't go high enough to "catch" the drip.
Old Apr 27, 2019 | 08:01 AM
Utinator's Avatar
Here are some photos of what I'm talking about:
You can kinda see the white silicone in the middle where the cowl overlaps. That where the water drips from.
Above, you can see the raised circle around the injector (driver's side shown). If you can "build-up" that circle, it should keep water out of it.
Old Apr 30, 2019 | 01:06 PM
RockinWs6's Avatar
I'll give you a little tip, next time its raining OR get the hose out and wet the windshield. Open the hood and watch the 50 places water leaks onto the engine. You need to seal the entire cowling AND the plastic rivets then test it to a extreme to be sure water can not collect on the intake.
Old Apr 30, 2019 | 02:28 PM
2ToeRacing's Avatar
RockinWs6,
I thinks some pictures would help
Old Apr 30, 2019 | 02:45 PM
RockinWs6's Avatar
Sorry I sold the car..............I know dumb.
Old May 2, 2019 | 12:15 PM
Volcente's Avatar
It is a common issue.
I've use a D weatherstrip and sylicone.
there is the nozzle hose that need to be sealed in the point where comes under the cowl and each front hardwere (5 hardwere)
you have to do a clear work because sylicone don't like dust and dirt.
