Any Engine Builders Here? need some help on a piston setup
My setup
RHS talldeck 9.750
4.250 stroke crank
6.460 rod
ETP C5-R head 40cc chamber
so if my math is right
2.125(stroke) + 6.460 = 8.585
9.750 — 8.585 = 1.165 compression height
i found a set of Diamond pistons that have
4.130 bore -23cc dish and a CH of 1.163
would these work or are the numbers too close.... do you round up the stroke+rod to 8.60 ?
with my cc head and a .041 gasket wouldn’t i have something like 13.6 to 13.8 to 1 compression.
Would these Pistons Work?
also gonna spray no more than 200hp nitrous.
RHS talldeck 9.750
4.250 stroke crank
6.460 rod
My setup
RHS talldeck 9.750
4.250 stroke crank
6.460 rod
RHS talldeck 9.750
4.250 stroke crank
6.460 rod
it would be used with a nitrous plate, but im not trying to scatter it either, so no more than a 200 kit with my edelbrock nitrous controller ramping tge power in....
i just dont see any other option than a big dish piston because of my cylinder heads combustion chamber
