Ls3 lsx swapped tahoe!
Hello everyone I just recently got a aluminum 2013 LS3/L94 I believe. I was looking to achieve 500+rwhp if possible. Now I was originally going with the F-35 cam, but I decided to go a different route since a lot of trucks & cars already have that cam. So I went with Spikes Performance custom grind cam specs are 245/258 not sure on lift .64X
to go with this cam I needed to flycut my pistons. I went ahead and milled the heads .40 to get some more compression. I have Full Bolt ons as well as a trutrac differential followed with some 4.11s. I have a 4l60e worried that thing will blow soon especially because of my 5C torque converter. Truck is running on E85 only. I swapped out to the 450 walbro fuel pump and running 50lb injectors. I will more than likely upgrade in the future to bigger ones. Not sure if to install 4.56 gears or stay with 4.11s. I have a nitrous kit but I doubt this cam is good for spray. My question is how much power do you guys think I’d be pushing to the wheels? What do you think 1/4 wise? Also this is my first 6.2 so what else should I do to get more power? P&P heads or a set of some PRCs or Mamo heads? I was considering the Holley hi ram intake as well. Thanks in advance for the feedback, going to try it out this weekend at the racetrack I will keep everyone updated.
