LQ9 Stroker with truck heads
I’m half way through sourcing parts for pro 2 build number 2. Last time I took the complete pull out from an 06’ GTO and swapped it into a 90’ 240sx.
This time around I’ll be using the same base chassis, but putting the motor together in a more race purposes fashion for higher rpms and reliability. That said we’re going with a stroker crank that is slightly under 4” giving us a better stroke to bore ratio. This is going to an all motor car for the time being, just to give you some background.
my question is as follows; will the truck heads fit under the hood of the 240, because we aren’t allowed to modify it to accommodate larger heads.
Also In talking about higher RPM configurations, if anyone has some recommendations for piston/cam combinations that worked well up to 8500 rpm I’m all ears.
thanks.
thanks.
Hi I'm doing cam, fast 102 and a bunch of other upgrades on my 06 bom gto.
192.168.100.1 192.168.1.1
thanks.
thanks.
The following users liked this post:
cookseyb (07-11-2020)
