Dash AC vents not working
Has this prob too
It’s a vaccine line. A small... black brittle vacuum line. I accidentally cracked mine when I was removing my Ecu, found the line and where it was cracked (took forever to locate) and threw some electrical tape on it! Fixed it right up! And haven’t had an issue yet. That was about a year ago. Same symptoms you’re describing. Gotta find that line and follow it.
I have solved it
So in my case the issue was the vacuum line that runs from the check valve to the firewall. It had a split in it. So what i did was just throw a new line on there and now it works fine. Thanks to all for the help and i hope this helps others in the future
The following 2 users liked this post by Edrock:
bigbomber5 (07-30-2020), SwiftSS (08-04-2020)
