Running without a radiator?
I'm inching closer to first startup on my motor. Does any one have a solution for running without a radiator, while still having coolant in the system? Maybe some kind of loop? I want to get it up to operating temperature. Thanks!
The following users liked this post:
B52bombardier1 (10-22-2020)
You can fire up your car to make sure it's going to start without a radiator, when I did my head/cam swap I buttoned the motor back together and fired it to make sure all was well before I put everything back together
Just make sure you loop the trans lines together so you dont spew trans fluid all over the place
toddrparr (10-22-2020)
