Flatbed towing - 02 Firehawk
So....my car does not start (most likely a dead starter). Yes, I tried whacking it (the starter, not the car). The car is sitting in an indoor car storage facility and I need to get it to a mechanic. My car is in a perfect condition and I don't want to damage it while loading/unloading. How do I get it up on a flatbed? I spent a while under the car and I can't find a single place to use as a towing point. I saw some people suggesting to use holes in the k-member, but I think the whole will become deformed and the chain/strip will damage the underside of the front bumper when tensioned. Obviously attaching to control arms is not an option....I like my suspension the way it is now. I also found this https://vorshlag.smugmug.com/Product...cts/i-mTvWQL8/ but it does not seem to be available anymore.
Any ideas?
Any ideas?
When we were towed out in NM due to a flat tire, we had to get a flat bed tow truck from AAA. I told the driver about everything and how difficult it would be. He did attach the cable from underneath the engine area and slowly loaded the T/A onto the truck, even using wood planks to lead it on. Even with all that effort the exhaust tips still scraped underneath. Unloading was about the same at the tire shop. A few scrapes under the tips was not the end of the world for us (can't see it unless under car) on a long 5,600 miles vacation but if your Firehawk is MINT then you really are going to have to be watchful. If we cared enough to wrap the exhaust tips beforehand we may have eliminated the scrapes. Just something to consider ahead of time since you have that luxury of planning ahead. I don't think I would want to tow it from the rear as the front chin spoiler is bound to get it. Good luck!!
The following users liked this post:
wannafbody (01-03-2022)
Apparently it can happen if the car sits for a while and is not started regularly. I already tried starting it with an external battery pack (that works on other V8 cars). A bad relay is an option, but I live an hour away from the storage place, so every time I go there, it's a 3-hour trip. If the car was in my house, I'd have time to play around with it, but now it's about a way to get this done with minimum time and effort on my part.
LS1Tech Administrator
Received 1,792 Likes
I agree with wssix99. FWIW, mine has sat, unstarted, in dry storage for at least 5-6 months out of every year for the last 23 years and it hasn't lost a starter yet. Relay issues, on the other hand, seems to be more common. Depending on the exact symptoms, I would re-evaluate the situation before considering a tow. I understand that the car is not easy for you to reach, but if the issue is due to a relay then the entire towing experience, and all risks associated with such, can be avoided altogether as that repair could easily be done in your storage unit.
More in-depth diagnostics (such as checking for power at the starter) can certainly be done with the multimeter if the relay swap doesn't work, but that is by far the easiest first step.
Ungrounded Moderator
If it should happen to be a VATS problem, it's easy to make an initial diagnosis. If the SECURITY light in the instrument cluster flashes then VATS can't see any key resistor which usually means a broken wire as RPM WS6 has mentioned (assuming your key does actually have the resistor). On the other hand, if the SECURITY light stays on solidly (not just during the bulb test at startup) then VATS sees resistance - just not the correct one to match its programming. On a low mileage car, this is most often due to grime on the key pellet or on the contacts inside the ignition cylinder... just keeping your keys in your pocket can be enough to cause a buildup which may not be immediately obvious. You can clean the key pellet with a pencil eraser followed by rubbing alcohol. The contacts inside the ignition cylinder can be cleaned with some spray electronics cleaner and a pipe cleaner or even a cotton swab (a pipe cleaner is less likely to leave residue).
Since it takes so much time to get to your car, it wouldn't hurt to take along those supplies (and even a spare key if you have one) when you go to try swapping the relay.
As of now I don't see how I can get the car on the flatbed with zero damage, especially knowing how "caring" and "careful" most tow truck drivers are. I'm trying to find a mechanic (or at least someone knowledgeable) to come out and at least diagnose the starting problem so I can understand what my options are.
NC01TA (01-05-2022)
How did he drag the car onto the bed? Do you know where exactly where he attached the straps? How did you avoid bumper damage?
Make sure to try the relay swap mentioned above on your next trip as well; super simple, rules out one primary possibility and requires no mechanic or tow truck.
wannafbody (01-04-2022)
I'll also double check all the fuses and re-seat them just in case. I did that in September already, but will do it again just to be sure.
