Collapsed Afm Lifter???
So my wife drives a 2010 Yukon xl, 5.3. The last couple weeks it’s been intermittently misfiring on cylinder 1, ticking very bad and running very rough, but it comes and goes. I’ve changed plugs, wires, oil pressure sensor, cleaned mad, move coil pack 1 to cylinder 2. Keeps miss firing on 1.
So I pulled the rocker cover and both rocker arms on cylinder 1, at top dead centre there’s about 1/8” difference between the 2 push rods…… does this confirm collapsed lifter before I tear it apart?
When an AFM lifter collapses, it stays collapsed.. What does the plug look like? #1 & 7 will oil foul real bad.
Otherwise according to your pic of the pushrod being lower, was the cam lobes both on the heels of the lobes? basically TDC on that cylinder.
If you do do lifters, replace the VLOM, that is usually the primary culprit of a lifter failing.
Also, from the looks of the lifters, you really need to run a better oil. That Valvoline **** ain't cutting it.
But you need to check the cam lobes and/or a roller on the lifters for any type of damage. One little nick will make it misfire.
After you fix it, do whatever you need to to disable the AFM, the lifters won't activate which you have a 99.9% chance a lifter wont fail and it will probably not burn oil anymore. With AFM on, I see the usual 1 to 2 qts of oil burnt every 1,000 miles.
I work at a dealer, have done more of these than I can count and customers pay me on the side to disable it via HPTuners. I tuned over 25 Police cars (Caprice) and none ever had a lifter failure.
When I lost a afm lifter on my 07 5.3 I didnt think I was even going to make it home, but did just barely. Lifter was collapsed. Replaced all lifters with regular jobs, new 5.3 non-afm cam, and sent the ECM out to have the afm disabled. 40k miles later still running perfect.
The following users liked this post:
Biebs (04-14-2022)
I've backed off from heavy work due to health issues here at work. But I was doing 2 to 5 lifter jobs a week at one point. Which I didn't mind, kept me from rebuilding these POS 6L80s.
Ya that’s the plan, from the research I’ve done…. I can leave the high volume pump and oil relief valve in place…. Change cam, lifters and tune it…
