Turbo vs Stall
Turbo vs Stall
For a 4th gen with an auto, which setup would stress the rear end worse? A full bolt-on stock LS1 engine car with a Yank 4000 or a car with a turbo making 450-500 horsepower? With the turbo car having a 3400 or so turbo converter.
LS1Tech Administrator
Received 1,685 Likes
Power alone isn't as much of a factor as things like wheel hop and launch shock (traction). Here's an interesting thread on durability of the 7.5" with an auto (as opposed to a manual). You'll see that the rear can take quite a bit with an auto as long as things like wheel hop are not present:
Best 60 Foot on Stock 7.5"?
The following users liked this post:
Y2K_Frenzy (02-07-2023)
I imagine the turbo car would spank the dog sht out of the bolt-on car even if the turbo car had the stock stall. Turbo that thing. It’ll be “quick” and “fast” vs just “quick” with the stall. Drag car or street car?
My belief is that an auto, especially a stalled auto, doesn't have the shock instantly, and therefore whatever shock there is gets spread over more teeth in the diff over time. So same power spread out over more of a surface basically. Even when revved to the TC wall, there is still a little slip/buffer action happening instead of an instant dump.
And as mentioned, wheel hop and other things like that count as shock as the wheel spins free and slams back to road speed.
I think in your example it'd not be much different between those two.
