Best LS engine?
A 2000ish 6.0 iron block with a stroker kit and LS3 heads is a good combo that doesn't break the bank. My one of my current hot rods is a 98 Wrangler with a rebuilt LS6/4L60E combo and has been bullet proof for 15 years.
My current project is a 80 Camaro with a 2012 L92/4L60E combo. The L92 is dressed to look like a LS3. I just got it tuned and it runs great.
Really depends on your budget and goals with your project. I am believer in build it once. Don't band aid stuff.
Factory rebuilt (ATK via Jegs..) < 3500 for the long block. The L33 gets a Specific Truck cam that pulls right off idle (625 RPM) to 5500, I have the redline set there..
NOt saying its the best, but it is a tidy package.
reliable and efficent in stock form
great for a performance build in NA or boosted
Dime in a doozen = cheap
While technically there, I doubt the difference is noticeable. Furthermore, is that really a priority for these swaps? I seriously doubt it.
GM uses the smaller bore to accomplish better fuel efficiency and EPA compliance. That's the view point I was referring to. If I were doing a swap, I would absolutely get the biggest bore I could find and afford, unless it's an LS7. You can have the LS7. I'll take a 5.3 over an LS7 any day.
To me the 5.3, especially in Gen V format is one of those. The 5.7 is indeed more powerful, but at a cost disproportionate to the size difference. It would be interesting to see GM's rationale for dropping the 5.7. 6.0 and 4.8.
