i have a 4.8 liter with a fab intake, shorty headers, stage two cam and ported heads. i have a 4l80e and a 3000 stall circle d converter but my car is wayyyy to slow anything will gap it unless im going around 50 which is where my down shifts line up but either way i know i make the most power in higher rpms it just takes so long to get there. i know its something wrong with my gearing or drivetrain cause the 4l60 i had on it before made the car have way more power off the line i have 273-308 gears(not sure but it is in that range) but i just bought 3.90 gears hopefully that'll make it gain that power back. let me know what you think the issue is. bro a 335i gapped me its a 1967 gto so the weights around 3400-3700
I have a 4.8 liter in a heavy pig....... 4.56 gears helped a lot.
11 pounds of manifold pressure helps too.
Let that short stroke motor SPIN !!
"It all comes down to Traction, GEARING and Manifold Pressure."
Reason: edit
Not only are the gear ratios hurting your combo. The 4l80e takes more hp to turn. Your rear gears are awful. 390's will help a lot. Put the 4l60 back in
The fab intake is hurting you too. A stock TBSS intake would be much faster and tons more torque throughout the range. It's ugly, but it works. Post your cam specs, I bet that's its touch too much, too. When your are building the little motors, the details matter more.
