Cooling system pressurizing itself!!!!
LS3 in kit car everything is fine ~7k miles never overheated, no heater, newer radiator, 2 small bypass holes in T-stat. One day wanted to check coolant in the morning. Lifted the level and it spewed 1 quart of water with loud bubbling/boiling sound. Only run distilled. Filled it back up, came out the next morning and it did the same thing. The engine has not been run in 48 hrs.
Now with plugs out and looking good, radiator cap off, I am watching water drip out of the overflow tube at 1 drop a second. Something is expanding in the cooling system
Runs, drives, cools great.
HELP!
HELP!
Blown head gasket. Take a look at the following You Tube videos and buy yourself a "Block Check" test kit. The kit checks for the presence of combustion gases leaking into the coolant past a blown head gasket.
Rick
Rick
https://www.youtube.com/results?sear...ock+check+test
Rick
Rick
Rick
Rick
