Do you let your motor warm up?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You want to drive it ASAP so you don't have time to dilute your engine oil with condensation build-up. If you have a stock t-stat then it's not such a big deal as most of the condensation build-up in the oil is cooked off but with most of us running 160 stats, it's a good idea to get in, start it, let it build oil presssure for a minute and then drive keeping RPM below 3000 until oil temp is up to 150 or so. This will also increase the longevity of your valve springs.
i usually ping the engine at 6000rpm for about 2 min then floor in reverse out of the parking lot and then do 2 brake stands to warm the drivetrain and tires
it seems to get that tick out of the engine!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
1 Post
LMFAO...
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I let the car warm up till it finds idle. Then drive easy to let the drivetrain parts warm too. In cold weather (below 20) I always drive easy. There's less wear on the gears.
![Icon Cool](https://ls1tech.com/forums/images/smilies2/icon_cool.gif)
#32
what also helps is if you turn the car on then off then on then off. it activates the single discharge capacitor in the engine data configureation managment accumulator. which in turn compresses the overall simualtion SAS heater.....heating the engine and other major parts![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
comon just turn the damn car on and let it sit for a couple of seconds!!!!! then drive and dont floor it for a bit
#37
Good, i was just making sure that when i started it up in the morning and do my usual burnouts down the street that im not going to wreck anything.......................................j/k
But seriously i guess that i should have nothing to worry about as long as i dont beat on it right away when i start it up. My daily routine is to start it at 7:18-19 and leave at 7:20 and take the 5 min drive to school and then shut it down. Or if im in a hurry i atleast let the RPM's drop.
I'm sure condensation builds up in it from the short drives, but thats why i take it for a 15-20 mile drive on the weekends.
Thanks for the help guys.
#40
Man some of this stuff is just outrageous...
Few things to point out... Our cars in mostly stock form are nothing close to supercars or anything of the sort, they are just cars and they were designed to be driven by GM. When I say this I dont mean start your car and start reving it high (back in High School there was a kid with a 68 Camaro who would do that, funny thing was he was in Automotive... Shows what that program taught) but could you see yourself explaining to a passenger "oh we gotta wait here for a few minutes, gotta let the engine warm up... otherwise it might break".
I usually start it up, turn on my lights (have to use lights all day here), adjust my seat if I have to, buckle up, etc... and then keep the engine below 2k until its warm. (knock on wood)
With karts or small formulas, they are "warmed up" by doing small bursts of throttle and gradually increasing the rpm.
