Free Mods!!
Originally Posted by presto_z
why is it a BAD idea for dig races?... i can see where it would offer little or no gains in that specific situation but not really a bad idea....
but ya it deff is good at higher speeds and roll races...
Our cars have a lower air dam under the rad assy. This creates a high pressure area of air that is then forced upwards. There is a large plastic screen in front of the rad, this directs flow over the rad assy and onto the engine.
The stock airbox only has an opening in the front, now although this doesn't directly feed off of this air it is where it sources it from.
The FRA opens up the bottom of the air box and removes part of the plastic screen on top of the rad, this is essentially tapping into this high pressure cooler air from the air dam.
At speed the air flow will be very good and it will be cool air (or as close to ambiant as your are likely to get. The faster you go the better it will work, because the air dam needs air flow velocity to work.
However if you are at standstill you have no air flow at all the air dam simply isn't working at all. And this means the air trapped between the plastic screen and rad will become more heatsoaked. Once you are moving it will clear and become useful again, but from a dig it will raise IAT (intake air temps).
In stock trim the airbox would be taking air from infront of the rad screen and not behind it, hence better IAT's from a dig. But it then looses out once moving.
The FTRA or SSRA use ducting from below and infront of the bumper. This results in two affects.
Firstly it acts as a cool air duct, it is taking intake air away from the heatsoaked engine bay/rad assy. This works at speed, but crucially at standstill also.
Secondly, as it is a narrow ducting which then opens out into the air box (an opening of the passage) there is cause to claim that at speed it will increase air pressure (alla Ram Air). But but having this ducting it also helps with a thing called air box resonance.
Most of the gains however are due to IAT's.
but the pros of the RA deff out weigh the cons....
Someone needs to come out with a solenoid operated SSRA that stays closed until you hit about 20 mph, ala the old '70 Chevelle SS (which was vacuum operated, I know) This would allow the best of both worlds. Just a thought...
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
the 69 Camaro was the first vaccum operated cold air induction i recall.
the old sales slogan "insert foot, open mouth"
Originally Posted by Magno222
o well i like what i paid for .. it responses quicker now...
I bet rolling on 1/4 tank of gas does more than all that crap you listed without the change of sucking something into your MAF wires or coating them with oil.
Whenever my car was getting tuned the shop descreened my MAF (had a stock one to put back on if it didnt work) and it was worth about 5RWHP if i remember correctly, and no ill effects. My car runs rich, not lean.
5rwhp is nothing. That could be due to different temperature, airflow, dyno error, ect.
#32
Administrator
Originally Posted by StealthZ06
I would HIGHLY advise against descreening the maf.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Porting the MAF though?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
it alone.
#33
Originally Posted by unit213
...and I would HIGHLY recommend that it be descreened. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just descreen it and leave
it alone.
it alone.
