Traction woes
Originally Posted by JKDZ28
Mind telling us what you lost to?
Originally Posted by SOM02WS6
are you running stock rubber now?
tires are the number one thing to do. All of your suspenion mods that you can do will only be good if the tires will hook. If you don't have sticky tires, your limiting yourself.
Originally Posted by 5_02ls1
the non blown saleen is no different than a stock gt.what mods did it have.yoiu should have blown past him spinning or not.405 hp vs a considerate
285.he had to be spraying.
No, actually it's one of my buddies, so I know for a fact he wasn't spraying. We did a 1st gear punch from about 10 mph. I sat there spinning while he hooked and left. I was RAPIDLY fetching him when we shut down about 65mph. My tires were cold, but so were his. I had my car on the dyno about a month ago, I put down 350rwhp (his is only rated at 340 fly), AND I've got about 400 lbs on him. I could use new spark plugs (when it was on the dyno, they said it was detonating pretty bad), could this be part of my problem?
Here's the car, it's pretty sweet. He's got the full Saleen suspension, and the 3:73 gear option.
Or try actually "racing", lol.
Seriously 10-65mph is only a blip of the pedal not a race. I mean a stock C5 z06 can go from standstill to 60 in just over seconds. From 10mph you should have more available traction, so that race only lasted what 5 seconds?
But yeah as others have said, if you have tractions issues lay off the gas a bit and be smoother. Going WOT is not a good idea if you can't use it, 50% throttle may have actually been faster.
But play to your and your cars strengths. The C5 z05 is a beast of car with plenty of top end. And if you are having issues racing from a dig or low speed try and run from a higher speed over a longer distance.
Having the fastest car is one thing, but racing is about driver and conditions.
If you are worried that the drag radials that everyone is telling you to get will upset the fine handling of your Z; another solution is to use R compound open track/road race tires, but right now it looks like you're limited to Pirelli Corsas in the stock Z06 rear size. If you don't mind giving up some left-right response, they're right, the BFG new tread drag radial is available in that size and will help your launch quite a bit.
