General LSX Automobile Discussion Non-technical LSX related topics.
Interesting stuff!!!
Old Nov 18, 2006 | 07:50 PM
BLKWS.6's Avatar
Default Interesting stuff!!!
http://forums.corvetteforum.com/prin...=906208&pp=100
Old Nov 18, 2006 | 08:50 PM
SPANKY LS1's Avatar
That debate has gone on since the beginning of time. They work, period. They need tuning so that the fans come on sooner to really shine, just a 160* thermostat by itself won't do much.
Shawn
Old Nov 18, 2006 | 09:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I do not beleive in low temp t-stats for LS1 motors, unless they are running boost. For NA setups, 190*F is as low as I'd want to run the motor.
After looking at and experiancing both sides of the spectrum, there is nothing that anyone can say to change my mind.
Old Nov 18, 2006 | 09:34 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I have mine set at 195*.
Old Nov 18, 2006 | 09:47 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Very interesting information...
Old Nov 18, 2006 | 10:49 PM
S99TA's Avatar
i dont run a t-stat car rus 195* going down the road and 210* at idle
Old Nov 18, 2006 | 11:38 PM
BLKWS.6's Avatar
Mine sits on a HAIR UNDER 210 normally and if I idle a lot it will go to 210 or a 1/4 needle thickness over it.
Old Nov 19, 2006 | 07:23 AM
y2k_ta's Avatar
'Bird Director
The factory temp guage isn't known for its accuracy.
Old Nov 19, 2006 | 07:53 AM
LS1Formulation's Avatar
Unless you have a '98 car, the factory temp gauge is worthless.
Old Nov 19, 2006 | 08:15 AM
unit213's Avatar
Administrator
+1
That thing always sits at 210 no matter what.
Old Nov 19, 2006 | 10:41 AM
BLKWS.6's Avatar
Originally Posted by unit213
+1
I wont argue the point, but if I let her set it will get a hair over, and when tis warming up it slowly heads for 210. I dont understand. I can agree its not the most accurate, but its not a "dummy guage" like fords oil pressure guage is it? If so, what OTHER guages in my car are worthless?
Old Nov 19, 2006 | 11:31 AM
RPM WS6's Avatar
Yes, it is basically a dummy gage on the '99+ cars. It will sit within a fraction of 210 (over or under) when the engine temp is anywhere between about 180 and 230.
On the other hand, the '98 gage will register even small changes in temp, and though it's not perfect either, it makes the '99+ gage look totally useless.
Old Nov 26, 2006 | 11:00 PM
TryingT/A's Avatar
I have a 160 degree thermo and mine runs at 190. The guage might be close to useless on an 01, but my tuner said it would run at that temperature. I chose to get the thermo because my faith does not lie in stock parts.
Old Nov 26, 2006 | 11:26 PM
BrandonDrecksage's Avatar
all of them besides the speedo. the tach is to slow causing some people to tap the limiter in 1st and 2nd while its registering low. The oil preassure is a dummy of course, coolant will read a hair under 210 from 180-230 or so. volts is actually accurate to my scan gauge. Fuel gauge will read e but when i fill it up, i would still have 2-2.5 gallons in there.
Old Nov 26, 2006 | 11:28 PM
BayAreaSS's Avatar
I was thinking about getting a lower t-stat but i dont want a 160. Does anyone make a 170 or 175?
Old Nov 27, 2006 | 12:50 PM
dailydriver's Avatar
The easy way around this is to install a shift light of your choice. It is a necessity if you are going to be seriously rowing an M6. If you are worried about this looking too "ricey", they can be hidden in vents/dash openings/etc.
Old Nov 27, 2006 | 02:11 PM
i have a shift light, I was just listing the useless gauges
