Things to look for when buying a higher mileage LS1
What are some common things that would break on an LS1, especially with one that has 70-120k on it? I've heard various things about burning oil and oil pumps, but I don't know if these people know what they are talking about. I figured the best way to find out would be ask people that actually have LS1s.
some cars burn oil, some don't. Its kind of hard to get that from a test drive or looking at the car. I would just take it for a nice hard drive, if the car doesn't feel right, or has weird sounds, don't buy it. These cars are meant to take abuse and survive it with some basic maintence. Just don't be naive and listen to the guy when ever he says he never beats on it, becasue its bs. Some noise(piston slap) is commona dn nto really a problem, once the car gets warmed up, it sho9uld go away if it doesn't be cautious.
Originally Posted by Ironxcross
yeah, my lt1 does that sometimes when its cold. I'm talking about like are there certain gaskets that are prone to leaking, etc. What are some things to look for an abused ls1?
ps.
why buy a ls1 if you already have a lt1?
Well, I'm curious about them. Everyone talks them up so much, its kind of hard not to wonder a little. From what I understand, they are amazing motors, but nothing is perfect, thats why I wanted to know some trouble spots.
I was thinking of getting an LS1, but there really isn't a point until I need a car, I guess. It would kind of redundant to buy another car when the one I have works perfectly fine.
The best way to check for abuse is to look down the quarter panels next to the rear glass. If there are slight ripples or dimples along this edge it means the car has had pretty bad chassis flex. It can be from fishtailing aggressively or by adding slicks and racing it at a track.
This is why I'd find a clean car, lower mileage, and as a first mod weld in some sub frame connectors.
Take the Bellows and Air Lid off and look at the throttle body if it is a pre-01 model. You can tell if the PCV has been shooting some oil at the TB blade. Besides that there is a seal where the driveshaft meets the differential I cant remember what seal/gasket/bearing it is, but that can tend to sling fluid on the under carriage. Just to be safe, just check the usuals, serpentine belt, air filter, oil/oil level, codes. I have 100k+ on my Z28 and havent had a mechanical or drivetrain problem yet (stupid window motor is all). Goodluck
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I know on A4's there is an inspection cap on the tranny that you can pull off to reveal part of the flywheel. If the rear main is leaking there will be oil in there, not much, but some. I had 135k on my old motor before I pulled it out, and it was still running just fine. I wouldn't sweat it!
