On road trip and rpms wont drop :(
When I take my foot off the gas in gear (M6) the car slows as it should. When I push in the clutch and put it in N and foot OFF the gas, rpms drop 1-200 then slowly glide up to 2500ish. I have no SES light. Sometimes it does this, sometimes they hesitantly drop, other times (once) my rpms dropped to 600 and refused to go up again to the normal 750-800. This problem is fixed when I shut off/re-crank it.
I think this might be the IAC, where is it located on an F-body? Is it that selenoid thing on the upper/driver side of the TB area? Opinions? Help, this sucks
Okay, removed/sprayed IAC with de-greaser. RPMS drop a lot faster, idle smoother, problem fixed.
1200 miles on 10-30 M1 EX performance, 80% highway
@1/4 qt. used. Sounds like my LS1 doesnt drink much oil at all, considering most LS1's go through M1 like gangbusters. Will be goin with 0-30 GC next oil change, hopefully it wont make the valvetrain louder like 10-40 Syntec did anywho, loving it
Originally Posted by Specialized
this whole thread was basically blkws6 talking to himself..
You look quite foolish in my eyes, sir.
I was seeking advice as to WHY my rpms rocketed to 2500 when I put it in neutral...I just found out for myself before anyone got a chance to tell me, and posted my findings for those of you who may or may not have/run into this problem. Creating an archive, if you will, for this problem, so that in the future someone with "search" could find it. When I searched it, I got hazy/half baked info that may or may not relate to my issue.
dont spray your IAT, its the IAC.
Originally Posted by PowerShift408
Hey, my car does the same thing. Time to spray the IAT sensor. thanks BLKWS.6.
And I'm not joking at all, he accomplished his goal to help.
DO NOT! press/pull on the "rubber plunger thing" it could hurt it, just hose the snot out of it with carb-cleaner and try to squirt it into its internals. hose her out good and you may be able to avoid buying a new one
