Service Manual DVD's - thoughts?
I have 3 different GM vehicles in the Driveway; ( 2ooo Trans AM + a 98 & o3 ZR2 Blazer, ) so I was looking at the service manual information that you can get now on DVD's.
I looked at Flea-Bay with little luck ( I guess I cant search for a hill of beans ) and thought that I'd pose it out to yall in "Z-Land."
I found this Service-Bulletins.com site and was wondering if anybody has dealt with this and or knows where I can get one for of-course less?
The paper manuals are ~95.oo - 125.oo for a specific vehicle and I thought that being that there are tons of them in there + the ones that I have that it would be worth it.
Printing the pages out is not an issue as I can do it at work as long as I buy the paper.
Thoughts?
Thoughts?
I have that one, I found it on eBay. I think it was around $30. Mine covers from '98 to '04. It has detailed repair instructions for most of the car's systems. I use it whenever I'm thinking about doing a mod or repair. It shows the different tools you need to do the job. It is handy to have. I sometimes print out repair instructions if they are tricky, or need torque specs. Otherwise, I just read it from the screen.
Yes, they have wiring diagrams called "Power Distribution Scematics" which is broken down in 19 catagories like :
"ABS BAT SOL, ABS BAT-2, HORN, H/L DOOR-HORN, LH HDLP DR, RH HDLP DR, and TCS BAT Fuses " They are block diagrams showing the item, the wiring path and color, and the junction/connector blocks.
Another section is called "Ground distribution scematics" and it is broken down into 15 catagories.
Each scematic has the zoom and print options.
Hope this helps...
Hope this helps...
